RE: No 2nd gear?
i think maybe because it doesnt have one...but its its a ntc3 you should screw in the set screw on the clutch shoe on the two speed all the way in then about two screws left then rev the engine and you should hear n see it shift(tires balloon hella big) n then you have your starting point turn in to make it shift later in the rpms or screw it out for sooner.
