No 2nd gear?
I just bought a tc3 and it was running fine but now for some reason it wont shift into second. If anyones has any ideas to why then please tell me but i already tried changing the shifting point to a lower rpm but that didnt work either but it helped my 1st gear for drifting lol!
i think maybe because it doesnt have one...but its its a ntc3 you should screw in the set screw on the clutch shoe on the two speed all the way in then about two screws left then rev the engine and you should hear n see it shift(tires balloon hella big) n then you have your starting point turn in to make it shift later in the rpms or screw it out for sooner.
K just so everyone knows i have a tc3 plus and yes it is nitro with the 2 gears. I know this cause it worked when i first got it and now for some reason it doesnt. Thank yo for your help but still no results.
