RCU Forums - View Single Post - To modify a 4stroke cam
Old 12-22-2004 | 10:35 AM
Meesh's Avatar
Meesh
My Feedback: (135)
Default RE: To modify a 4stroke cam
Bill,
If you reground the cam profile with the intention of increasing valve overlap, you would have to add material to the cam ramps first. The mushroomed tappets effectively do just that by causing the valve to lift sooner and stay open longer. If you simply removed material from the ramps you would cause the valve to open later and stay open for a SHORTER duration.
Bob
