RE: To modify a 4stroke cam
Bob:
You have misunderstood. You do not cut the ramps only, that definitely would decrease the duration. By cutting the base circle you can increase the lift, if you also cut the crown of the lobe you can increase the duration and maintain the original lift.
Yes, as I said earlier, the mushroomed tappets do increase the duration without having to modify the cam lobe.
Bill.
