RCU Forums - View Single Post - What Turbine
Thread: What Turbine
Old 12-22-2004 | 12:29 PM
mr_matt's Avatar
mr_matt
My Feedback: (10)
Default RE: What Turbine
OK I found it...
Dieter Perkuhn tested 5 different ECUs for the Jan-Mar 2003 issue of RC JetPower Magazine. He used a sensitive spectrum analyzer (Rhode and Schwarz) for all of the tests. He charted radiated emissions performance over a frequency band from 30 to 40 Mhz (this is an excellent article by the way, I wish he would run the same tests at 72 Mhz)
One quote regarding the Projet ECU performance:
"It is almost identical to the results obtained with the new JetCat electronics"
BTW in this article the quietest ECU was the AMT NL peice.
And guys, thanks for the kind words, all of those guys at JetCat USA are working hard for you. As Keith has indicated (and appreciated) many times, quality service is what you should expect from JetCat USA. If you ask me you get what you pay for with the service.
