RCU Forums - View Single Post - Calculating compression ratio
Old 12-22-2004 | 04:29 PM
knarF
Default RE: Calculating compression ratio
I have the strong suspicion that indeed compressions ratio is calculated from the point of all ports closed.
My self converted OS10FP (with 2 piece contra ) and .46 OS run fine at approx 1:19 / 1:20 CR. (calculated from all ports closed, it must be the fuel i guess ) If I would calculate the CR from pure bore*stroke for both engine i would end up with a CR of approx 1:14/ 1:15.
My mix is 54/33/15/2 or so (I have hard time remembering numbers lately )
Best regards,
Knarf.
