RCU Forums - View Single Post - Setting Up AFP(D) To The Max
Old 12-22-2004 | 10:42 PM
matt3D
Default RE: Ask Maarten DeMoor - Tweaking AFP(D) To The Max
ORIGINAL: Doc. insane
Mike, I know what your talking about, I lllloooooovvvvveeeeeee that ERIC CLAPTON guitar solo.
Matt, I just trimm the plane at full power levelflight. Than I check the uplines fot the sidethrust. IF this is OK than it should be flying normal.
When you say you check the uplines for the side thrust, do you mean the engine's degree's for right thrust?
Thanks for the reply,
Matt
