RCU Forums - View Single Post - OS 61FX help
Thread: OS 61FX help
Old 12-23-2004 | 10:10 AM
Primodus's Avatar
Primodus
My Feedback: (56)
Default RE: OS 61FX help
I have had 2 of these engines and the answer is YES. You can rotate the inlet. Also, the needle valve can be moved to either a side or top facing position. Remove the brass nut and swap it with the needle valve assembly if you want to swap positions.
