RCU Forums - View Single Post - Tango ARF
Thread: Tango ARF
Old 12-24-2004 | 02:33 AM
cairoman's Avatar
cairoman
Default RE: Tango ARF
David,
I have a copy (MSWord file)of the Tango manual. Please PM me your e-mail and I'll send it to you.
Chris
Here's a copy of the last page in the manual:
Section 5: Completion
1. Now we should have all our parts complete, so lets put it together. Take the fuse with gear down and install wing tube making sure it is centered. Then slide on the booms.
Make sure to hook up the elevator and rudder connections and slide the flap and aileron connections through the booms. Next take the elevator assembly and hook up the servo to the extension in boom and screw elevator assembly to the boom with 4 6/32 socket head screws and washers. Now secure the booms to the fuse with 4 8/32 socket head screws and washers. Slide on the wings and hook up the aileron and flap extensions. Make sure the wings are on tight and locate the dowel in the bottom of wing over the wing tube; drill and tap for 4/40 screw and install 1 in each wing panel. Place canopy in place and secure with rod.
Now we are getting ready to TANGO!!!!!!!!
2. Suggested throws:
Aileron Low: ¾ inch up and down
High: 1 in up and down
Elevator Low: ¾ inch up and down
High: 1in up and down
Rudder Low: Avery small amount for steering at take off ¼ in left and right
High: All you can get for aerobatics.
Speed brake: 40 degrees
Flaps: 15 and 30 degrees
When deploying flaps and speed brake both will tend to pitch the nose down so if you can it is a good idea to add up elevator mixing with flaps up to 20 percent to compensate. This is something that you will have to experiment with as each will be slightly different due to balance and weight ect.
Balance 5 3/8 behind the leading edge at wing root.
