RE: 33cc homelite muffler
I managed to take a Homelight leaf blower muffler & quieten down my 33cc to that equilivant to a large saito 4 stroke!!
4* 120 with a 33cc Homelight
The leaf blower muffler has 1 pipe (blowing into the prop when installed!) The "can" will come apart so I did that & rotated the outer side with the pipe to point to the ground. by doing this you will have to plug the old bolt holes on that side (small nut & bolt w/ some RTV) & use the ones on the other as a guide to drill new ones. Dont forget to re-install the roll pins on the inside that keep the muffler from crushing when you bolt it back on. I also went to Lowes & bought what I call "lamp tubes". The small threaded tubes used in mounting the shade fixtures on lamps. I drilled 2 more holes in the muffler beside the original & installed the lamp tubes using the nuts that come with them, one on the outside & one on the inside. Cut the end of the tubes at an angle to match the original tube, paint and you will have a very quiet muffler that dosent cut power. Not exactly the prettiest but definatly quiet. A fellow club member has a 4*120 just like mine w/ a Saito 150 & when we fly together you can hear his Saito over my 33 Homelight. I know that may be hard to believe but all I can saty is try it your self!!
Oh yea, since the muffler originally came off a 25cc you will have to take a Dremmel tool & widen the exhaust hole on it. The lengths are the same but the widths are slightly different. Bolt holes are no different.
One more tip. To make muffler (of anykind) mounting easer on the 33 & 45 cc Homeys. Save to original muffler bolt. Use a Die to make the threads longer & cut some of the bolt off to the length desired. If you have a muffler such as the B&B they are recessed for an Allen head bolt rather than a nut like you have on the 33 & 45. Since I have access to a milling machine I just make the recess big enough to accomidate a nut but if you dont have the tools use a small wheel collar as a washer to fit into the recesses area.
Good luck with what ever you do.
Happy Flying
Steve
