RCU Forums - View Single Post - Sledge Question
Old 12-24-2004 | 07:40 PM
3D ONdaEDGE
Default Sledge Question
Hello everyone. I got a question for you profile guys. Is anyone flying one of the Sledges or OMP edges or EF Edge with an OS 70. When I was building the Sledge, I built it wide enough in case I ever get a Saito 82. The only problem is that a TT 46 pro, which I was going to use until that time will not fit. The mounting rails are too wide to bolt the engine to. I could probably make it work, but I have an OS 70 that will bolt right up. I know the OS is a little heavier that the TT 46 or the Saito 82, but if this engine is not too heavy, I may no even get the Saito. I am not worried about the power. Heck the 46 is enough power, but I want a 4 stroke in the nose. Also I dont really need the extra power that the 82 has over the 70. Basically will the WEIGHT DIFFERENCE between the OS and the Saito affect it badly. Will it still be solid in a harrier with the extra weight up front, or should I just break down and get the 82. Thanks in advance for any help!
