ORIGINAL: ben beyer
, but he can't get a lot of throw out of the rudder servos. He has what looks like the bar for a DuBro HD pull-pull set up and the DuBro HD long servo arms. Are you guys using something different or just a longer aluminum servo arm to get enough throw? What's your set up?
I'm using the Dubro HD pull-pull set up, and a 2 1/2" long arm on my servo. I wish I had a bit more throw for knife edge loops.
If you can get a hold of a 3" arm, I would go with that. In doing so, I think your cables would line up better in the slots of the fuse where they exit at. Mine rub the sides just a tad, no matter if I cross them or not.
