RE: what type of glue
Your best bet is to find a mentor and learn while doing. This kind of teaching and advice is priceless. Opinions on bulletin boards are varied and most everyone has one. If you're so new to building that you need info on glues, by all means ask, as we were all new at one time, but an experienced helper can guide you through the process of building with a minimum of mistakes and backtracking. Unless the instructions that come with the plane are first rate, and you said they were not, I'd find some local help. Good luck!
