RCU Forums - View Single Post - Prophex's first plane
Old 12-26-2004 | 04:41 PM
Prophex's Avatar
Prophex
Default RE: Q: Where can I find an online dealer who ships to Europe ?
hmmm, all good advice, ...
BUT, in meanwhile, the plane is already built and everything works. I started it up today and ran it for 20 min. (had to stop, caus it was getting to cold outside and to dark) I didn't fly it yet, but my dealer told me to run in the engine for an hour on the ground with factory settings.
The building was a bit tricky and I had to take apart some stuff again to put some other stuff on and the manual was not correct. (Like: first you have to install the throttle pushrod and then the engine, not the other way arround like the manual said, caus otherwise you'll end up taking the motor of again like me)
I do have some questions: (didn't want to start a new thread)
- How long can you fly with a full tank ? And how can you tell when it's nearly empty ?
- How long does a fully charged 4-cell 600 mah battery last ?
- this is a long one: I think somethings wrong with the airelons. When I move the servo in one direction they move just fine, but when in the other, the airelons don't go as far as the other side. The servo seems to be installed correctly and the rods are also in place. (if necessairy, I'll post some pics)
thx for all the input,
Prophex
