RCU Forums - View Single Post - Prophex's first plane
Old 12-27-2004 | 02:20 PM
sigrun
Default RE: Q: Where can I find an online dealer who ships to Europe ?
Aileron not "airelon: (sic).
You need to find out why and fix it. Knowing the hinges supplied with the Skystar and suggested method of fixing, if you followed the instructions I'd suspect your aileron is either binding against an excess of epoxy at the hinge joint obstructing movement, or simply resistant because of the same reason. Other than that it's an uncentered servo or linkage adjustment and/or alignment problem inducing apparent unequal deflection.
You should have oil coming out of the muffler. Quite a lot if you're excessively rich runnng that engine.
The field should be - get an instructor - big. Flying your Skystar will not be as easy as RC flying seems on your simulator.
If you don't, it'll all end in tears.
