RE: GP Ultimate .40
As far as bipes go it should be a fairly straightforward build. The fuselage is jig locked and the cabanes are already built for you. They are not wire rods either which is nice to avoid. The fuselage is built like a brick firestation with dense balsa so if you can remove some wood here and there that is all for the better.
