RCU Forums - View Single Post - CA Glue on Fingers
Old 12-27-2004 | 08:17 PM
jettstarblue's Avatar
jettstarblue
Default RE: CA Glue on Fingers
Fer cryin' out loud! DO NOT USE CHEMICALS ON YOUR SKIN! Even de-bonder is bad bad bad. By the time you get the glue off, and wash your hands, the damage is done.
Soak them in warm water, or use some lotion and let it stay on there for a few minutes, then peel it off.
Another way, believe it or not is to add more glue until you get a good crust on your finger tip, then soak it, it should come off in one big "tip".
