RCU Forums - View Single Post - 7CAF timer
Thread: 7CAF timer
Old 12-28-2004 | 11:08 AM
Krysta
Default RE: 7CAF timer
Hi rjbarthel,
When in the timer menu, after you have "uninhibited" the program, press your cursor once to get to the time and set this accordingly. Press the cursor once more and you will be at Mode, then decide if you want this to be Up or Down, next press the cursor once more and use your scroll button until you get to 3 (throttle channel), here you will have the choice of letting this be up throttle or down throttle to trigger your timer. Once you have set this action the way you want it, you will need to move your throttle stick to the position up or down that you want this ti start at, then you should then just be able to press the Dial and hold it til it beeps and you should see your timer working on your main screen.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
