BME 50 prop off
Hi guys, I just purchased a used patty with a BME 50 I am trying to remove the prop I have taken the prop nuts off it is now just the prop on the shaft. I was told I should be able to move the prop counter clock Wise and the engine would stop on the compression stroke but the prop should still turn. THe problem is the propeller moves easily through the compression stroke. any help would be great.
Best,
Rob
