RE: VF edge 540 throttle linkage
Just use a z bend and you'll be fine.....no use using a clevis when the engine is that close to the firewall. Be careful when inserting the z bend.....the throttle arm is plastic on Saito's. Make your adjustments at the servo end. If you have a computerized radio...even better.
