RCU Forums - View Single Post - Precision Eagle 4.2 Performance Question
Old 08-29-2002 | 01:02 PM
DaleCS's Avatar
DaleCS
Default Re: Byron
No gear reduction, no belts. However, I believe I will get a prop adapter so that I can swing a two blade prop. This would at least let me get some comparative data on both RPM and thrust.
Thank you.
Originally posted by rcign
Byron made hub adapters for the larger engines...The two skinny polyflex belts won't transmit the power of a large engine..Iron Bay would be the best bet for info.................Best prop would be a 24-8 Menz or Mejzlik two blade for performance, leaving the multi blade for display.....
