RE: Is this possible??
I have a Futaba 9C radio. I do have a couple of models where each aileron has its own servo. One servo goes into the first channel and the other aileron goes into the 5th channel. However, if you "Y" the two aileron servos, and put this connection into channel one of the rx, how are you going to get the ailerons to move correctly? Example....if I turn left, wouldn't both servos move the same way thus
making each aileron move up? Or, would you position the servos so that the servo arms move opposite?
Dave...
