RE: Wing cracking at the mounting points on a 4*
That is indeed what is cracking and it was an ARF.. There is plywood where the screw head comes overlying the balsa.. However, the plywood had torqued into the balsa on both sides causing cracks.. I put a big plywood square over both screw holes (one piece) to fix and prevent future cracks..
Sachin
