SBR J, the instructions are pretty detailed (I thought) about this subject, you should be able to follow them exactly and be fine. Cables will not be the same length, most likely. The servo arm should be 90 degrees to where the cables enter the fuselage from the servo arm. Hope that helps, if not email me anytime at
[email protected]. If we cannot solve it via email, I will call you.
Jeff Williams
