RCU Forums - View Single Post - Pull-pull on the sledge.
Old 12-31-2004 | 11:12 PM
SBR_RV's Avatar
SBR_RV
Default RE: Pull-pull on the sledge.
im not sure but maybe im missing a page.
this is what mine says: install the the control horns onto the rudder and elevator, hook up the pull pull cables. use the outer most hole on the rudder control horn, and keep the cables tight, rudder flutter could happen:.
i got two pictures, one showing the servo arms on the bottom of the wing, but they werent 90deg to the cables enerting the fuse, i dont know, maybe its my fault for not figuring this out.
the other pic was just showing the cables hooked up to the elevator and rudder.
anyway ill give it a go at setting the servo arm 90deg to the cables enerting the fuse.
thanks for your help. ill report back when i get it done.
