RE: DeHavilland Mosquito
Hi, I have just completed a Flair Mosquito ( same as CM Pro) with a pair of SC 52 four strokes. Had problems getting the engines far enough back but I cut up some standard GF mountings so the carbs almost tough the bulkhead. This leaves about a 5mm gap between the cowling and the spinner but doesn't look too bad. Mossie also has Eurokit air retracts and oleo legs. Will post some photo's and let you know when it flies.
