ORIGINAL: loujoduo
Iam a retread to model building (control line in the 50s) my question is can you keep CA in the refrig. to extend its shelf life?
If you do keep it in the fridge, be absolutely sure the cap is on TIGHT. Moisture is what makes this stuff work so well, and it will absorb the moisture from that environment if not tightly sealed.
