RE: Typhoon 2000 (TEMPEST) modifications thread
Cutting the Tempest wing turned out to be quite interesting because the big difference between the root and tip. Even when cutting at low temperature there is a danger of the wing tip melting a little, the wire is just mowing so slowly at the wing tip. To take care of that I made the tip template a little oversize. On this wing I will be using 85gr m2 paper for sheeting with 3x5mm hardwood spars.
