RE: Typhoon 2000 (TEMPEST) modifications thread
I built the wing structure and glued the sheeting on (one side). I'm using rubber bands to hold the sheeting in place. It works good if you put weight on flat surfaces (near TE). I'm using a wood template to support TE in correct position.
