RE: Adjusting Thrust
Hi Edgar,
You are correct that LOW/MED/HIGH reduces the max RPM at full throttle, and that looking at the max RPM is the best way for you to verify that the thrust has been reduced. Your 2300 should top out at either 120k or 123k. Reducing the max RPM setting to MED/LOW will reduce full speed RPM in 5k RPM increments.
KM
