RCU Forums - View Single Post - CF pushrods causing interference?
Old 09-07-2002 | 08:52 PM
rgreen24's Avatar
rgreen24
Default cf push rod
If you are going to use carbon fiber push rods you need to support the pushrod inside of the fuselgae. Use a couple pieces of lite ply to support the cf inside of the fuse. Push them as far back as they can go down the fuse. This will help add support to the cf when doing thos 3d maneauvers.
