RCU Forums - View Single Post - .45 gfsr
Thread: .45 gfsr
Old 01-03-2005 | 08:43 PM
DarZeelon's Avatar
DarZeelon
Default RE: .45 gfsr
RB,
The new carburettor also has the same part number (#3216) and the same choke size (7 mm), but is a completely redesigned unit.
If the plane that you intend to use this engine in is a fast sport model, intended to fly primarily at either full power, or idle, you will have a sufficiently good performance and transition.
If your model will need to use frequent part throttle, it could load up the engine, since the mid-range fuel settings will be too rich. So for 3-D and the like you may want to either upgrade, or replace this carburettor.
This photo shows the new style carburettor (#3219 8 mm) in an MVVS .49.
