RCU Forums - View Single Post - 2 degrees right thrust
Old 01-05-2005 | 05:50 AM
J-MAN
Default 2 degrees right thrust
This is my Strega by Phoenix (Sorry about crapy photo's, crapy camera)
As you can see the motor is at 45 degrees.
To get the clearance for the prop on the cowl , I had to run the front two bolts of the adjustable engine mount though the engine mount holes.See pics.
So in the manual it is not clear if the 2 degrees right thrust is already incorporated into the model. And being a adjustable engine mount (not for me though because of bolts through engine) how do you get right thrust without down thrust? Because mount is on 45.
so how do I check. And if wrong how do I solve.
ID:	210845   Click image for larger version
ID:	210846   Click image for larger version
ID:	210847   Click image for larger version
