RCU Forums - View Single Post - 2 degrees right thrust
Old 01-05-2005 | 08:24 AM
Ed Smith
Default RE: 2 degrees right thrust
Looking at the picture of the engine mounting it would appear as if the engine is held in place with two screws and what will end up as a bent strap. That lot will shake loose and go into self-destruct mode. I would suggest you get a different mount where all four engine screw holes can be used. There is a disaster waiting to happen.
Ed S
