RCU Forums - View Single Post - Sig Somthin Extra - Finished and Flown !!
Old 01-05-2005 | 04:22 PM
kregan's Avatar
kregan
Default RE: Sig Somthin Extra - Finished and Flown !!
ORIGINAL: krossk
Advent,
I'd really love to see how you did the pull-pull on the rudder and elevator.
Did you have to move the servos?
I just switched the throttle and elevator servos and raised the elevator servo
up about 3/8" to clear the other servo's. I glued short 3" or 4" exit tubes
into the fus during constuction and ran all the wires prior to covering. Once
everything was in place I labeled the wires and removed them.
The rudder and elevator are rock solid with no slop at all. This is the first time
using pull pull, and I really like it. I used 60 pound test .021 dia. steel leader
purchased at BassPro shop, 100 feet was under $10.00 and sullivan 2/56 through
hole threaded rods with Dubro clevis's/clevie [:@] ??
