RCU Forums - View Single Post - ARC Ready 2 Trainer
Old 01-05-2005 | 06:00 PM
Test005's Avatar
Test005
Default RE: ARC Ready 2 Trainer
I have the Beaver and here's how I put an aluminium gear on after I broke the stock plastic gear.
My plane is heavy with a big fourstroke and a 1500mah battery and this mounting technique has worked well for many landings.
Just ask if you need any help or instructions, but I think the pictures explain it quite good.
Those are 4mm bolts and lock nuts. The wood is plywood.
ID:	211063   Click image for larger version
ID:	211064   Click image for larger version
