You might try
www.fancyfoam.com kits are starting at 329.00 High Performance Electric R/C Aircraft for the Experienced Pilot
Pitts Model 12 - Ultra High Performance Combination
This kit comes with the very best components for 3D Practice. As with most of our kits, the Pitts 12 is set up for dual aileron servos. This will allow you to mix the ailerons as needed for flaperon control and differential. It is strongly recommended that you use a computer radio with the ability to set dual rates and exponential. With the full flying stab and 70+ degrees of elevator travel, exponential makes flying a lot more fun.
Kit contents: Complete Pitts Model 12 airframe, precut and glue ready. Himax 2015-4100 brushless motor with Castle Creations Phoenix 25 speed control. GWS "D" gearbox, pinion gear and 12x6 prop. Hitec Electron 6 FM receiver with (4) HS-55 servos. Etec 1200 mah 11.1v, 10C LiPo battery pack with Deans Ultra plug connector. You supply the graphics, glue, charger and Transmitter! ...I have a Futaba 7ca on order with a apache 2500 Li-po charger for 189.00 to my door from
www.allerc.com.....This is my first ever and I am have fun getting it all together...cant wait to fly...best of luck!!!!
