RE: Poulan 36 conversion possible?
Zafer,
You'll more than likely not be able to run stock ignition on the 36cc.
The magneto is not mounted to the engine, rather to the case of the saw. (at least wasn't to mine)
However, it a VERY easy conversion if you want to go with CH ignition system. Thus adding about $150-200 to your project.
They are powerful little motors though.
If you'd like to keep stock ignition, I would look at the Homelite brand....they have the mag bolted to the engine itself.
Good Luck!
CrazyHerb
