RCU Forums - View Single Post - Setting Up AFP(D) To The Max
Old 01-08-2005 | 03:31 AM
  #54
Doc. insane
Default RE: Ask Maarten DeMoor - Setting Up AFP(D) To The Max
Kickflipkid687,
Did you program the tx like I did and did u use the same settings as mine? Then it should be quite realistic. If you can hover a shocky in real, then it shoudn't be a problem on aerofly pro deluxe.
