RCU Forums - View Single Post - U.S. AirCore 40 Trainer Kit
Old 01-09-2005 | 10:03 PM
birdnest
Default RE: U.S. AirCore 40 Trainer Kit
well samolot, I'm going to give you an opposing point of view. The aircore trainer is heavier and lands hotter (faster) than balsa models, so if you're working on landings, I dont recommend it. Crashes can damage the lite ply plate that the motor and electronics mount onto. This can be replaced. A Balsa model can also be repaired, unless you really plant it in the dirt. I found the aircore a real pain to build, particularly the wing. Building a balsa ARF is probably easier. If you are reasonably proficient at landing a primary trainer, then an Air core makes a nice back up model, or a half step up model. There are so many better choices though that I don't often recommend this model line.
peter
