RE: Shindaiwa weedy motor
So you guys think i should start with a 16-6 - 16-8 prop. Ok thanks. The carb on this motor is very restricted on the intake hole in the carb(.312 dia. on the outside .500 on motor side). Do you think if i bore the hole out to the same as the back side of the carb that it will give me more power? I know i will have to take the brass flap in the carb out to bore it. Let me know.
smallplanes
