RCU Forums - View Single Post - Builder Needed With Excellent Monokoting Skill?
Old 01-10-2005 | 06:03 PM
viper21
My Feedback: (9)
Default Builder Needed With Excellent Monokoting Skill?
Hi I need to have a Great Planes 40 size Patriot new in the box that I would like to have built and have the onboard radio installed. I have the Hobbico mechanical retracts and retract servo I have just about everything to build the plane including an OS 50SX and Macs pre tuned header and muffled tuned pipe. I would like to have to have the plane covered as its shown on the box and in the planes the Thunderbirds the color scheme. So I need to have someone with excellent covering skills.
I also have a Kyosho T-33 foam Electric Ducted fan thats built but I need to have it covered with Chrome Ultracote Plus the sticky backed Ultracote that needs no heat to apply however if go over the film with a very low heat setting with a covering iron it will stretch. The T-33 is all styrofoam so you need to apply the covering in sheets and use very low heat to seal and make sure its tacked down but you can melt the plane. The T-33 is allready built I just need to finish installing the fan, motor and radio.
I am willing to pay well for top quality work If your interested please email or PM me and I can give you the rest of the info on the planes. I just dont have the room or time to build the Patriot and I dont have the covering skill to cover these planes[]
Thanks Much Viper
Moderator, I did not know where to put this post so if needs to be moved I understand.
