RCU Forums - View Single Post - Engine Cutting out.,.
Old 09-02-2002 | 05:15 PM
Shapedlocket
Default Engine Cutting out.,.
Thanks Guys., i will give it a try, i do hold the nose up before take off, to see if it cuts but it never does, only seems to be when i take off, around 40 metres, then cut.
Ok ill try and do what u say, peak, then open it up 3 clicks, ill also try a bigger prop. maybe this is causing it to run too fast.
Thanks again.
