Warning Feature
OK, that's what I thought you meant. On my Stylus, you no kidding had to have the stick dead on the stop to get past the warning. Without having an RD, the only suggestion I can make is to pull down on the stop with the throttle stick and/or get the trim all the way down (if its not a digital trim), or maybe hit the kill button. Sometimes you can get a touch lower throttle throw by pulling on it. Sounds like a bad set range for the warning or a bad pot. Maybe you can get Airtronics to disable it or open up the range. Frankly I had to disable it on my Stylus because I couldn't stand not to have the radio come on.
