RCU Forums - View Single Post - Mosqitobite TriPacer Build started.
Old 01-11-2005 | 07:54 PM
  #91
wascamp
Default RE: Mosqitobite TriPacer going on the workbench.
The cover is complete. If you have used Koverall before this is no big deal. If you have not used it you are in for a pleasent suprise. As with most other planes we cover the bottom, sides and the top. With the tripacer I found that covering the sides was easier if the horizontal stab was not glued in. the stab gets in the way of the cover at the rear. Apply the material to the sides and cover over all the slots where the stab is glued, you can cut the fabric away with a knif after is has been shrunk. make sure to dope around the holes so the fabric stays in place when it's cut. Cover right over the window openings doping at the perimeter only. Once you shrink the fabric you can dope around the openings, When the dope is dry cut the windows out leaving about 3/8th to 1/2 inch of material. this is folded over the window lips and doped down. It is a nice finishing touch. As with the wing, the fabric is only doped at the edges. This covering system takes more time than film but it gives a very scale like finish. Any Questions?
ID:	213811   Click image for larger version
ID:	213812   Click image for larger version
ID:	213813   Click image for larger version
