ORIGINAL: abacro
.Now as to the other post byNogyro,think about what you said. You changed from a G-62 to the DA 50 and didnt have to add any weight toreballance,hmmmmmmmm seams to me then that the DA must WEIGH EXACTLY the same as the G-62.
Art
With the G62, I had two rudder servos mounted in the tail portion of the fuse, and 2-5 cell AA nicad packs mounted where the turtle deck starts. With the DA50, one servo for rudder pull-pull in the front cut out, and both batteries are mounted over the landing gear. I believe the plane weighs 1 lb. 6 oz. less with the DA set up.
