RCU Forums - View Single Post - Had to reverse the trottle servo, is this correct?
Old 01-12-2005 | 04:10 PM
shackscs
Default Had to reverse the trottle servo, is this correct?
When I setup the control arm for the throttle, I had to program in reversing the servo in order for the servo arm to throw in the correct direction. According to the manual "As the throttle stick is moved from the low position to the high position, pushrod B moves backwards as the servo turns counter clockwise".
Is this correct? I could not get the arm to go in the correct direction according to the illustration unless I did this.
