RCU Forums - View Single Post - Decathlon choice
Old 01-14-2005 | 10:05 AM
IronCross's Avatar
IronCross
Default RE: Decathlon choice
Then there is also the Seagull Decathlon... I have both the Global and the Seagull... Can't beat the Seagull for 139.00.... The Global is more expensive. It does not have the counter balances on the control surfaces, and the covering is not that great... Not quite sure what it is... If you try to patch it with Ultracote or Monocote it just "prunes" up... That and the edges don't stay down... The Seagull is much bigger, is covered with Ultracote and has the counter balances on the rudder and elevator giving it a more scale look... When I say scale however on both of them it is stand waaaay off scale...
