RCU Forums - View Single Post - Nav Lights & Strobes - Any Problems/Issues ?
Old 01-14-2005 | 10:32 AM
jetjockey
My Feedback: (8)
Default RE: Nav Lights & Strobes - Any Problems/Issues ?
Bob, I've used a strobe, a rotating red beacon and non flashing nav lights on a scale Eurofighter powered with a JetCat 120, 160, and a Simjet 3000. I've had absolutely no problems at any time with the lighting systems. I was a little nervous at first also, but did a range check and then flew repeatedly with no problems.
BTW, I'm working on a FiberClassics MiG15 that will have strobes, nav lights, and a beacon. I think if you install the lights, route the wires away from any ECU wires, do a good range check before you fly, and you should be OK.
Good luck, Les Morrow
