 Nav Lights & Strobes - Any Problems/Issues ? >
Old 01-13-2005 | 04:42 PM
My Feedback: (24)
Default Nav Lights & Strobes - Any Problems/Issues ?
Wondering if the Landing lights, Nav lights, and Strobe systems (like from Ram or other manufacturers) can possibly cause any problems/interference with the reciever or the turbine ECU ? I am considering installing some ....... but if there is even a very slim chance of a problem, then I will pass. Thanks. Bob
Old 01-14-2005 | 10:32 AM
My Feedback: (8)
Default RE: Nav Lights & Strobes - Any Problems/Issues ?
Bob, I've used a strobe, a rotating red beacon and non flashing nav lights on a scale Eurofighter powered with a JetCat 120, 160, and a Simjet 3000. I've had absolutely no problems at any time with the lighting systems. I was a little nervous at first also, but did a range check and then flew repeatedly with no problems.
BTW, I'm working on a FiberClassics MiG15 that will have strobes, nav lights, and a beacon. I think if you install the lights, route the wires away from any ECU wires, do a good range check before you fly, and you should be OK.
Good luck, Les Morrow
Old 01-14-2005 | 05:41 PM
Hi Les, any info on where you got your "rotating red beacon" ? I'm on the look out for one.
Dave
Old 01-14-2005 | 08:38 PM
Hey Les, what kind of strobes are you running and where did you get them? I am wanting to put on on my BVM F-16.
Thanks Chris
